Forums >> Revit Building >> Technical Support >> column's material
Wed, Aug 6, 2008 at 6:56:23 AM | column's material
emosms
 I am using modeling/columns in my building now. The columns acquire the material of walls they intersect with. That mess up a lot my floorplans.From the columns properties one can set the column material, but it persists to show the wall's material instead of what i set in the properties.
What to do now?
Best Regards
Wed, Aug 6, 2008 at 7:35:27 AM | column's material
This problem has been posted many times so a little searching in the forums would have answered your question.  The standard "column" is more like a pilaster and it will assume the wall material.  Use a structural column and define its materials as you would like.
Holding a wall off of a column line
Thu, Jul 20, 2006 at 3:08:57 PM
Column Capitals
Wed, Sep 18, 2019 at 8:39:07 AM
material tag schedule problem
Sat, Mar 25, 2017 at 7:50:36 AM
Using a C-Channel as a column
Wed, Jun 14, 2006 at 4:45:09 PM
Creating 'Alucobond' material
Thu, Feb 11, 2010 at 2:35:53 AM
Page generation time: 1.2083
