11 Users Online (9 Members):
Forums >> Revit Structure >> Technical Support >> Revit Structure model to ASD
3 Posts No Rating |
Can I export my Revit Model to AutoCAD SD?? I want to be able to generate auto connections. What is LE point in dwg it 2wice.
Ya surely u can export your revit model to ASD in dwg formatt
Chirag C. Pawar Cad Solution Application Senior Engineer KLGSystel Ltd. India 301, Pujit Plaza, Plot No. 67,Sector 11, CBD Belapur,Navi Mumbai - 400614, Maharashtra, India.Tel .: +91 22 409 16777. Extn. - 718Fax .: +91 22 275 76461.Mob .: +91 99 698 66851.Email.: chiragp@klgsystel.com Web .: www.klgsystel.com |
3 Posts No Rating |
Hey Chirag.. Yes I know you can export as DWG format. But it's DUMB dwg,ASD does not recognise the members as ASD geometry, so autoconnections does not work.......... HEEEEEEEEELP
I have never used Autocad SD but try exporting in IFC 2x2 or 2x3 format.
3 Posts No Rating |
Hello, You can use IFC export with revit extension. In Autocad SD in steel menu you haveDSTV data export Activate "Data exchange for steel construction (ISO-10303-21) and choose Import (auto) And choose you're IFC files with browse button. zinc73
----------------------------------- vive la tariflette |
3 Posts No Rating |
3 Posts No Rating |
3 Posts No Rating |
Hey Zinc73. I'm doin' something wrong as it doesn't work. By the way IFC is not an option. Only STP. Also, noticed that when I export using CIS/2 then import into ASD, dialogue pops up Unrecognised name changing. Does this mean that the sections in Revit need to match the sections in ASD.
Are u making details in Autocad Structure Detailing or revit? |
Thu, Mar 25, 2010 at 9:20:32 AM
Revit Structure cooperate with Autocad Structural Detailing, HOW??? |
Mon, Mar 29, 2010 at 2:33:21 AM
AutoCAD File import in Revit Visual style (Shade) Problem |
Tue, Aug 13, 2013 at 2:40:23 AM
SketchUp into Revit Structure 2009 |
Fri, Feb 27, 2009 at 9:51:24 AM
Problems with the Revit Structure Analytical Model |
Fri, Apr 20, 2012 at 2:43:36 PM
