Forums >> Revit Building >> Technical Support >> Edit System Family: Room
Tue, Aug 5, 2008 at 5:20:54 PM | Edit System Family: Room
Bimmer32
I'm using using Revit 2009, and would like to know how to add additional Identity Data to the system family: Room. I know how to add parameter to custom elements, but I cannot find the button to "edit family" when it comes to "room."
Wed, Aug 6, 2008 at 7:21:43 AM | Edit System Family: Room
Create your shared parameter then add it under project parameters ... rooms.
Wed, Aug 6, 2008 at 11:33:35 AM | Edit System Family: Room
Bimmer32
Got it. Thank you for the help. I knew it was possible and was comfortable with parameter manipulation but I did not know where to go the access the shared parameter and project parameter.
Editing Room Label / System Family
Sun, Jan 31, 2010 at 7:32:44 PM
How edit system family: Elevation
Tue, Mar 28, 2006 at 3:30:46 PM
Editing System Families
Sat, Dec 5, 2009 at 3:53:10 PM
Beam System is not resetting after I edit the boundary.
Mon, Jun 15, 2015 at 2:35:42 PM
Revit 2012 - Edit Room Boundaries
Tue, Jul 5, 2016 at 2:42:16 PM
11
Page generation time: 1.3046
