19 Users Online (17 Members):
Forums >> Revit Building >> Technical Support >> converting dimensions
Is there a tab to switch on to see a dimension both in Imperial units and Metric units while working in revit 2009?
i don't think we can do that in Revit yet?
I assume you are referring to the temporary dimensions. You can't have both display at the same time. Its one or the other. You can only have two separate dimensions styles to display both at the same time, but these must be manually placed.
Regards,
Chris.
converting masses? |
Wed, Nov 22, 2006 at 2:48:08 PM
Any known problems converting projects to 2009 form 2008? |
Thu, Aug 21, 2008 at 5:49:13 PM
EQ Display in dimensions Revit 2009 |
Tue, Mar 23, 2010 at 3:28:36 PM
Isometric Dimensions in Drafting Views (details) |
Fri, Sep 28, 2012 at 3:13:08 PM
Changing Dimensions |
Mon, Feb 7, 2011 at 9:02:52 AM
