Forums >> Revit Structure >> Technical Support >> wall height defined by ceiling
Tue, Aug 5, 2008 at 2:59:02 PM | wall height defined by ceiling
archi3
so working in revit 2009 and I was wondering if it were possible to have the height of a wall defined by the ceiling/floor above without attaching the wall?
Tue, Aug 5, 2008 at 4:18:22 PM | wall height defined by ceiling
Belinski
4 Stars: 5 Votes
you could attach the wall to the level of the ceiling/floor
Wed, Aug 6, 2008 at 12:01:31 PM | wall height defined by ceiling
archi3
is there a way without attaching to the ceiling/floor above?
Wed, Aug 6, 2008 at 12:20:10 PM | wall height defined by ceiling
Belinski
4 Stars: 5 Votes
you could play with the wall offsets, and just offset it a certain distance away from the level that the floor/ceiling is attached to.
Wed, Aug 6, 2008 at 2:18:42 PM | wall height defined by ceiling
archi3
thanks
my boss doesn't want me to mess with the offset, or to attach the walls. those are the only ways I know, is there any other way?
Wed, Aug 6, 2008 at 2:22:20 PM | wall height defined by ceiling
broncos4life
3.5 Stars: 11 Votes
Why not attach?  That is really simple, whats the reasoning for not wanting to do that?  That really is the only real way to do it.
Wed, Aug 6, 2008 at 3:16:01 PM | wall height defined by ceiling
4 Stars: 205 Votes
Yeah, why not? what's the reason for you boss?
Thu, Aug 7, 2008 at 10:21:43 AM | wall height defined by ceiling
archi3
not to sure why, except that we were told when creating a floor to say no to the two windows that pop when you finish the sketch. as for attaching floors on an individual basis, I have started to attach walls where it works best. but I was just wondering if there was any other way that I haven't figured out yet.
also is it possible to attach a floor to a wall? that way an exterior wall can go up multiple floors and the incoming floor plates can attach so that they cut into the structure creating a platform and not a balloon framing. if I create the exterior as multiple walls and attach to the floor, then the end of the floor plate comes through the facade is not continuous up the facade.
locking height of family to ceiling height?
Mon, Apr 27, 2009 at 5:29:03 AM
Revit 2016 How to set the wall height to respond to ceiling heights?
Sun, Apr 24, 2016 at 6:09:20 PM
Ceiling height column problem in schedules
Fri, Dec 7, 2007 at 10:23:16 AM
Room Name w/ manually entered Ceiling Height
Mon, Jan 19, 2009 at 3:50:30 PM
Add Ceiling Height in Room Schedule
Mon, Nov 19, 2012 at 9:38:54 AM
Page generation time: 0.8585
