11 Users Online (9 Members):
Forums >> Revit Building >> Technical Support >> zero suppression
22 Posts No Rating |
revit 2009 how do you suppress 0' 6" dim to read as 6" in the project settings. I was able to edit the text style in one dimension string, and updated the others. but is this a setting that can be controled in the project settings itself. because to be able edit the dim text I had to uncheck 'use project settings' thanks
Go into Settings-->Project Units and change it there.
"Go into Settings-->Project Units and change it there." http://screencast.com/t/ESpQ94mdPs
Zero Suppression in Level elevations |
Fri, Jan 16, 2009 at 10:10:54 AM
RCP and RFP |
Tue, Aug 24, 2010 at 1:01:44 PM
Super-Duper needed Revit features |
Thu, Mar 15, 2007 at 3:52:25 PM
MEP and Architecture Intigration |
Mon, Jun 8, 2009 at 9:52:17 AM
New to Revit |
Thu, May 17, 2007 at 5:52:23 PM
