Forums >> Revit Building >> Technical Support >> Custom Hatch Text Files
Tue, Aug 5, 2008 at 9:33:11 AM | Custom Hatch Text Files
TigerARCH
I have created a custom brick pattern of 12 x 24 inch blocks.  At the third course from the bottom, I need to add an 8 x 24 course and then continue with 12 x 24 blocks above it.  Is this possible through just text editing the .PAT file?  I have read through most of the forum topics and would rather not purchase Hatchkit 2.7 just for this one time use.  Any suggestions or ideas?  Thanks in advance.
Tue, Aug 5, 2008 at 9:40:39 AM | Custom Hatch Text Files
I don't blieve this is possible ... even if you do purchase hatchkit.  Hatch patterns are simply a repeated group of commands.  They started way back when we had pen plotters and were pen up ... distance ... pen down...
Tue, Aug 5, 2008 at 9:41:14 AM | Custom Hatch Text Files
Use your main pattern, then come in and edit face and apply the smaller pattern.
Tue, Aug 5, 2008 at 9:52:16 AM | Custom Hatch Text Files
TigerARCH
That's pretty much what I thought.  Thanks again.
Tue, Aug 5, 2008 at 10:02:12 AM | Custom Hatch Text Files
lunchtrayrider
3.5 Stars: 7 Votes
if it were EVERY third course then yes, otherwise what wwhub said.
I like scooters. and motorcycles.
Tue, Aug 5, 2008 at 10:04:15 AM | Custom Hatch Text Files
TigerARCH
Out of curiosity Lunchtrayrider, how would I do it for every third course?
Tue, Aug 5, 2008 at 11:16:21 AM | Custom Hatch Text Files
ArchWestCY
4.5 Stars: 7 Votes
Why not use the hatch pattern that you have, and use a Host Sweep => Wall Sweep to add the single course of the other size block?  That way you can see it in 3D, you can easily adjust it up or down, it will be cut by windows and doors, and you could even give it a slightly differnet Cut Pattern to designate it in section views.
I would have to agree that trying to edit a hatch pattern to do this sounds harder than is necessary.
ArchWestCY
Tue, Aug 5, 2008 at 12:46:31 PM | Custom Hatch Text Files
TigerARCH
I thought about that as well, but the 8 inch block isn't a sill or an extruded course.  It is just another course of the same width and depth, only 8 inches tall instead of 12.  In addition, a wall sweep doesn't "cut" the wall pattern so it doesn't start over above it, it only continues behind it.  I appreciate the idea though.
Tue, Aug 5, 2008 at 1:01:44 PM | Custom Hatch Text Files
ArchWestCY
4.5 Stars: 7 Votes
A stacked wall would do you right.  Make it 3 peices.  The first would be the portion of the wall below the 8" band.  Then next wall protion would be the 8" band, and then the rest of the wall would be on top.  That would fix the hatch pattern staring over problem.  Stacked walls are kind of cumbersoum to edit, and I don't use them all the time, but it might work best in your case.
ArchWestCY
Tue, Aug 5, 2008 at 2:38:58 PM | Custom Hatch Text Files
lunchtrayrider
3.5 Stars: 7 Votes
if you were editing the .pat file you would just make three rows and it would repeat.
Mon, Dec 22, 2008 at 1:32:19 AM | Custom Hatch Text Files
#11
hugh
3.5 Stars: 4 Votes
Sorry I'm late to the party, TigerARCH.
The attached pattern has 3 courses of 24" blocks being 12, 12 then 8" tall.
Have a look at it with the HatchKit Demo to see how the pattern repeats on a skewed grid.
Compliments of the season,
Hugh Adamson
Cadro Pty Ltd
www.hatchkit.com.au
Hugh Adamson
www.hatchkit.com.au
Hatch Pat files how to?
Tue, Oct 3, 2017 at 3:03:38 PM
custom hatch pattern without hatch editor
Wed, Jan 28, 2015 at 8:46:58 PM
Imported hatch patterns appear corrupted
Thu, May 21, 2015 at 3:16:53 PM
Custom Hatch Patterns on Revit [ 1 2 ]
Fri, Jul 31, 2020 at 1:39:38 PM
16
Is there a way to preview .pat files / hatch patterns in thumbnails in a folder?
Mon, Jul 6, 2015 at 11:01:26 AM
Page generation time: 1.4418
