Forums >> Revit Building >> Technical Support >> CONTROLLING THE ORDER IN WHICH SHEETS ARE PRINTED
Mon, Aug 4, 2008 at 2:42:09 PM | CONTROLLING THE ORDER IN WHICH SHEETS ARE PRINTED
raredmon
Is there any way, in Revit 2008, to control the order in which the sheets are sent to the printer. If I was able to edit this, it would save a ton of time spent reordering the sheets once they have been printed.
Mon, Aug 4, 2008 at 3:21:19 PM | CONTROLLING THE ORDER IN WHICH SHEETS ARE PRINTED
Belinski
4 Stars: 5 Votes
Yes, after you pick what sheets you want to print, check the 'reverse print order' box
Mon, Aug 4, 2008 at 4:19:56 PM | CONTROLLING THE ORDER IN WHICH SHEETS ARE PRINTED
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
You can create a shared parameter and apply it to the drawing sheets category and enter numerical values for each sheet. You then can arrange the sheets in the Project browser using those values as the sort by parameter.
Mon, Aug 4, 2008 at 4:49:06 PM | CONTROLLING THE ORDER IN WHICH SHEETS ARE PRINTED
James,
The problem is that the displayed order for printing has nothing to do with the browser order.  The print display order seems to be purly alphabetical and I don't see a way around that except by breaking the order up into groups that are alphabetical and printing those in the proper sequence.
Mon, Aug 4, 2008 at 5:10:39 PM | CONTROLLING THE ORDER IN WHICH SHEETS ARE PRINTED
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
I'm sorry, I misunderstood your question. I was thinking about the browser order not print order. I am not sure if there is a way to arrange the print order.
Tue, Aug 5, 2008 at 1:18:31 PM | CONTROLLING THE ORDER IN WHICH SHEETS ARE PRINTED
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
I found out the there is a Batch Print Utility available for Autodesk Subscription Members that allow you to control the order in which you print. I have not used it but if you are a Subscription Member it might be worth a look.
controlling drawing order of views on a sheet
Mon, Mar 7, 2011 at 12:30:49 PM
Plot Order
Tue, Jan 3, 2012 at 9:40:18 AM
sheet index order with Linked models
Sun, Mar 13, 2016 at 12:37:27 PM
Drawing list sheets are in incorrect order
Fri, Jul 9, 2010 at 10:59:05 AM
Sheet Number Order
Wed, Oct 15, 2008 at 10:30:38 AM
Page generation time: 0.1527
