Forums >> Revit Building >> Technical Support >> Open 2009 Files in 2008
Mon, Aug 4, 2008 at 12:18:50 PM | Open 2009 Files in 2008
ZachBeale
Quick Question,
 When you save a file in 2008 format from within 2009, then it is opened and saved in Arch. 2008, and finally opened again in 2009, will all of the Mental Ray materials primarily applied in 2009 carry through?
 I ask because I am to be working and rendering in 2009, with the rest of the group in 2008. When i save the file in 2008 format and the file is opened by other users on 2008, then saved, once I reopen it in 2009, will my materials and other render settings carry through and still be present after I open it again?
Thanks!
Mon, Aug 4, 2008 at 12:36:21 PM | Open 2009 Files in 2008
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Good question. Like most, I uninstall 2008 after I got 2009 running so it's hard to test. There's only one way to find out. Run a test and let us know. My guess is 'no it will not work', but that's just a guess. Someone else may already have the answer for you and post it. It's all about the materials library.
Mon, Aug 4, 2008 at 12:47:56 PM | Open 2009 Files in 2008
broncos4life
3.5 Stars: 11 Votes
How are you saving Revit 2009 back to Revit 2008?
Mon, Aug 4, 2008 at 12:54:00 PM | Open 2009 Files in 2008
lunchtrayrider
3.5 Stars: 7 Votes
and how were you planning to save back to 2008?
I like scooters. and motorcycles.
Mon, Aug 4, 2008 at 12:54:38 PM | Open 2009 Files in 2008
lunchtrayrider
3.5 Stars: 7 Votes
lol i walk away and someone beats me.
Mon, Aug 4, 2008 at 12:59:19 PM | Open 2009 Files in 2008
ZachBeale
Well, I'm not sure if you can save back or not, I've never used 2009 before.
Mon, Aug 4, 2008 at 1:09:48 PM | Open 2009 Files in 2008
coreed
coreed Avatar
4 Stars: 16 Votes
ZachBeale, i think they are pulling your leg. what you want to do is not possible to do with Revit.
Edited on: Mon, Aug 4, 2008 at 1:11:18 PM
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Mon, Aug 4, 2008 at 1:10:04 PM | Open 2009 Files in 2008
lunchtrayrider
3.5 Stars: 7 Votes
I think the short answer is you can't do this.  The best solution would be to simply save a duplicate copy and then do renderings, but i wouldn't plan on taking it back to 2008.
training files for 2008
Sat, Dec 24, 2022 at 4:48:32 PM
is it possible to open Revit 2009 files in Revit 2008?
Wed, May 14, 2008 at 10:02:04 AM
Can't open SOME Revit 8 files with Revit 2008
Mon, Jul 9, 2007 at 9:33:05 AM
Revit 2009 corrupted files
Tue, Mar 10, 2009 at 9:30:34 AM
Revit IFC export and NavisWorks 2009
Tue, Nov 18, 2008 at 11:15:34 AM
Page generation time: 1.7432
