Forums >> Revit Building >> Technical Support >> How to create a Glass Block Wall?
Tue, Apr 19, 2005 at 8:15:35 AM | How to create a Glass Block Wall?
JOYSMIDNIGHT
3 Stars: 1 Votes
Does anyone have an idea of how to create a glass block wall or better yet does someone already have one created that would be willing to share? There is only one small problem, the design of this wall will include several different "colored or textered" blocks within one wall to make a random pattern. Is this possible or do we have to treat each "color/texture" as a seperate wall?
Tue, Apr 19, 2005 at 8:46:37 AM | RE: How to create a Glass Block Wall?
Arnel Aguel
In your Revit mateiral library there is already a glass block material that you can use. If you want different colored glass then try using mosaic tile material but adjust the transparency value as the default is opaque. If there are random patterns use split face tool then paint it with your desired material. Post edited on 2005-04-19 08:59:27
Tue, Apr 19, 2005 at 5:44:36 PM | RE: How to create a Glass Block Wall?
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
You could also use the curtain wall and setup a system to have a particular vertical and horizontal grid spacing. Then swap out the panels for those that are of the glass block depth and of the appropriate material. Personally though it would be less overhead to the model to do it Arnel's way.
Wed, Apr 20, 2005 at 8:15:38 AM | RE: How to create a Glass Block Wall?
JOYSMIDNIGHT
3 Stars: 1 Votes
I actually ended up just creating a family for the glass block and we copied and stacked it around. That way we could just select the appropriate ones the needed to be changed for the random pattern. I've attached my glass block file for anyone you wants it.
Tue, Apr 17, 2012 at 9:40:51 PM | How to create a Glass Block Wall?
amszpara
Is there a way that i could insert that Glass block into a curtain? I would liket o creat a curved long wall with glass blocks, and stacking them individaully could take a while.
Anys suggestions?
Wed, Apr 18, 2012 at 7:24:21 AM | How to create a Glass Block Wall?
Jut use the regular wall with the glass block as your material.  It can be curved ... It is after all basically the same as concrete block... individual units with mortar joints - just somewhat transparent.
Fri, Apr 27, 2012 at 6:54:28 PM | How to create a Glass Block Wall?
amszpara
Thanks a lot!
Mon, Mar 20, 2017 at 7:18:28 PM | How to create a Glass Block Wall?
Madmachinist
OK totally ignoramus newbie here.  How do you modify the glass brick in Revit so that it will be 8X8X4 like the one readily available at store and also how do you create that grout line which is about 1/2 " thick.  Haven't had much success with curtain wall tool in doing that.   basically I am trying to draw that glass block window in the pic.
Edited on: Mon, Mar 20, 2017 at 7:24:09 PM
Mon, Mar 20, 2017 at 7:23:13 PM | How to create a Glass Block Wall?
It is a masonry wall but with the material set to glass block.
Mon, Mar 20, 2017 at 7:25:42 PM | How to create a Glass Block Wall?
Madmachinist
overall masonry wall and the material is set to glas block. so how do you set teh grout lines and how about the glass brick size?
Mon, Mar 20, 2017 at 9:21:46 PM | Madmachinist
#11
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Quoting Madmachinist from 2017-03-20 19:25:42
See this.
Tue, Mar 21, 2017 at 7:23:18 PM | How to create a Glass Block Wall?
#12
Madmachinist
doesn't work well as it is not adjustable and definately not the right size.  Neither was I able to remove 2 columns of the glass block.  I'd make an array from scratch if I was able to find an accurate object and knew how to make teh grout line.
Tue, Mar 21, 2017 at 10:23:07 PM | How to create a Glass Block Wall?
#13
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
There might be some flaws with this family (Idk), but what do you mean it’s not adjustable? It looks like everything is adjustable but thickness of the grout.
Thu, Mar 23, 2017 at 6:51:59 PM | How to create a Glass Block Wall?
#14
Madmachinist
OK, I see no parametric arrow to grab and stretch or my favorite, boxes in which to change teh heighs and widths of the blocks.  Now when I am on interior view there is a box for block height and when I change it to 8" from 6", It just changes the lines in the interior and not teh exterior.  BTW, I don't need 4 block wide only two, how do I get rid of the other two?
I have been able to change the height of teh block but that is it.
Edited on: Thu, Mar 23, 2017 at 7:03:25 PM
Glass Block Wall
Wed, Apr 20, 2005 at 12:04:41 AM
Glass Block Wall
Wed, Feb 23, 2011 at 2:01:24 PM
Glass block
Sun, Jun 4, 2006 at 12:38:25 PM
glass block wall
Tue, Mar 2, 2004 at 9:49:52 PM
glass plank wall
Sat, Sep 27, 2008 at 10:34:22 PM
Page generation time: 3.1978
