Forums >> Revit Building >> Technical Support >> casework tag: loaded? unloaded?
Sat, Aug 2, 2008 at 11:54:50 PM | casework tag: loaded? unloaded?
ICON1962
I try to tag a vanity: message says " no tag is loaded for this type, would you like to load one?
I say yes.
in the imperial library folder I select "casework"
I select "domestic bathroom"
I select the tag with the same name as the vanity had in the browser and click open.
I then get the message, "family "......" is already in use in this project. Overwright existing version?"
I select yes, but don't check "override parameters"
I get message "Family is not of correct category"
The tag will tag a wall but, not a vanity.
Why can't I select the vanity?
 I go thru the same sequence for a shower tag and get the same result, again tagging a wall but, not the shower.
Sun, Aug 3, 2008 at 6:00:38 AM | casework tag: loaded? unloaded?
timbo89
timbo89 Avatar
4 Stars: 5 Votes
Hey, when you are asked to load a tag, you have to load an annotation object; you can't select the vanity with the same name as this is a model component. To load a tag, you have to select something from the annotation folder in the imperial library. I haven't found a casework tag, but there may be some out there. Create a generic tag (file-->new-->annotation symbol and select "Generic Tag"Winking and under settings-->family parameters and categories select "casework tags". Create the desired labels and load it into the project, and now you should be able to tag the casework. To tag your shower, change the family category to plumbing fixtures.
  • Core 2 Duo E8400 3ghz
  • 756mb Nvidia 9600GSO 256bit
  • 6gb Kingston RAM 800mz DDR2
  • Windows XP Service Pack 3 32-bit
Fatal Error when adding casework tag
Mon, Apr 6, 2009 at 12:38:40 PM
Casework not loading into project
Thu, Aug 15, 2013 at 7:36:39 AM
material tag
Tue, Jun 9, 2015 at 8:49:15 AM
Tagging equipment nested in casework family
Wed, Aug 1, 2012 at 3:32:56 PM
Revit link unloaded v2014
Mon, Mar 17, 2014 at 4:14:34 PM
Page generation time: 0.2930
