Forums >> Revit Building >> Technical Support >> WHY WILL SOLID BLACK "ANNOTATION FILLED REGION" NOT PRINT!
Fri, Aug 1, 2008 at 12:17:00 PM | WHY WILL SOLID BLACK "ANNOTATION FILLED REGION" NOT PRINT!
raredmon
Why do annotation filled regions (solid black) not print at all? I have an annotation symbol for my exit signs that use an annotation solid black filled region - it looks good on screen, but the sold black DOES NOT PRINT!  Please help if you have a suggestion!
(P.S. - It is a nested family, the symbol is nested into the exit sign generic model to show up on plan)
Revit Arch. 2008
Fri, Aug 1, 2008 at 12:52:30 PM | WHY WILL SOLID BLACK "ANNOTATION FILLED REGION" NOT PRINT!
TABEST
4 Stars: 4 Votes
in your symbol family, try settings->family categories, click the keep visible button.  Verify that your solid black filled region is indeed a proper solid black (things change in Revit, so you never know for certain that it is right).  Is it showing up in print preview?
Sun, Aug 3, 2008 at 1:51:22 PM | WHY WILL SOLID BLACK "ANNOTATION FILLED REGION" NOT PRINT!
JustinT
Just a thought, but try setting you printer setup options in Revit to Raster instead of Vector.....
Justin
www.revitup.co.za
"Solid white" filled region that prints in black
Mon, Aug 1, 2005 at 8:47:27 AM
Help needed to Align a Filled Region to a "family" (Deck Span Direction)
Mon, Jan 14, 2008 at 12:38:56 PM
Detail Component / Filled Region
Wed, Aug 19, 2009 at 10:57:44 AM
Why won't my Filled Regions print?
Tue, Sep 2, 2008 at 3:38:22 PM
filled region pattern color changes when drawing scale changes
Thu, Apr 14, 2016 at 7:32:06 AM
Page generation time: 7.1005
