11 Users Online (9 Members):
Forums >> Revit Building >> Technical Support >> Revit 'Building" not representing consistenly in Revit 'Mechanical'
10 Posts No Rating |
Please help me understand: When my mechanical consultant imports my 'building' model into his 'mechanical' model, my 'Compound Ceiling: 2X4 ACT system' represents correctly in his first and second floor RCPs but represents incorrectly as a 2x2 ACT system in his third floor RCP. Thank you
This could be a VG issue, a phase issue (if you are using them). Could it be a workset issue?... I have not done enough copy-monitor to answer that.
This sounds dumb, but verify that you indeed do have the proper ceiling type in your model, also have mep try to delete the 3rd floor ceiling... perhaps someone accidentally put one in their model...? check your model with all worksets on to verify there isn't one hiding in a particular workset. Create a new project and link in your project to see if you can recreate the problem... perhaps this will give you some insight. Beyond the above, Dunno why, it is a Revit thing! Good Luck
''Visibility grafics'' and ''create parts'' problem when mak |
Fri, Mar 19, 2021 at 11:45:46 AM
I need to change my building levels from 0'-0" to 100'-0" |
Sat, Sep 11, 2010 at 8:03:55 PM
12
Change 0'-0" MAIN LEVEL to 100'-0" |
Tue, Aug 22, 2006 at 7:40:49 PM
Revit 9.1 "what's new?" |
Tue, Aug 29, 2006 at 11:44:41 PM
Need some assistance |
Sun, Dec 25, 2005 at 1:31:10 PM
