22 Users Online (20 Members):
Forums >> Revit Building >> Technical Support >> Show brick veneer in coarse view
Using Revit 2009 I have a brick on concrete wall system. In mu coarse view, I would like to see the brick as two lines and the concrete as a hatched region. Is this possible?
Plan ... elevation ... where?
In Plan
Just set the pattern for the concrete wall to what you want for coarse. Goto the properties of the wall and set it there. DO NOT EDIT THE WALL coarse fill it set seperately from element fill patterns.
The result is mis-leading beacasue it hartches the entire wall. I want to see the double line of brick separated from the double line for the concrete. Any thoughts?
Maybe the defenition of a coarse fill precludes the ability to add lines within walls?
By golly ... I think he has it!
Brick veneer stepping at alternate elevations |
Wed, Aug 14, 2013 at 8:28:36 PM
230 brick wall wont cleanup to 250 brick veneer wall (images attached) RA2008 |
Wed, Sep 3, 2008 at 12:33:09 AM
New Wall with Brick |
Tue, May 26, 2009 at 9:36:24 AM
BRICK VENEER WALL |
Fri, Jul 22, 2005 at 8:55:04 AM
Existing 12" wall w/4" brick-4" cavity-4" brick. Can't get plan brick to s |
Wed, Apr 8, 2009 at 5:08:39 PM
