19 Users Online (17 Members):
Forums >> Revit Building >> Technical Support >> drawing construction lines in elevation
I get an error message when i try to change properties of a stone wall on its section/side elevation so that i can make it into a tapered wall it tells me to open in a different view which is the front or rear elevation which is not the view i want to change, can someone point me in the right direction on this please.
Thanks
40 Posts No Rating |
You can't edit a wall proifle in a side view or section view you can only edit the profile in the wall elevation. To make a tapered or slanted wall use in-place wall creation.
sorry, but how do you do that
In the Modeling tab click create icon then select wall category click solid/ extrusion then sketch the profile of your desired wall in any elevation that you want. Take note a profile must be a close loop.
thanks
Elevation lines and bubbles on sections and elevations. |
Thu, Aug 30, 2012 at 2:05:14 PM
Elevation lineweight in regards to depth |
Fri, Aug 18, 2006 at 10:35:40 AM
phasing |
Mon, Dec 27, 2004 at 7:30:20 PM
visibility of glass panel lines in elevation |
Tue, Aug 11, 2009 at 5:55:02 PM
Construction Drawings in Revit |
Thu, Oct 20, 2005 at 8:21:56 AM
