Forums >> Revit Structure >> Technical Support >> Custom Property Line Tag
Thu, Jul 31, 2008 at 4:42:03 PM | Custom Property Line Tag
PanTerra
I am in need of a property line tag that is in the following format;
Angle:   "Degree(s)"    "Minutes"   "Seconds"
Distance:   "xx.xx m"   "Cryingxx.xx ft)"
 I've searched several websites, including this one with no luck.  I've even bought Paul Aubin's latest "Mastering Revit Architecture 2009".
 Any help would be appreciated.
 Thanks.
PanTerra
Fri, Aug 1, 2008 at 9:30:40 AM | Custom Property Line Tag
I believe the tag reads the angle using the format set for your project.  Check the setting under options/site settings and look at the property data units setting.
Fri, Aug 1, 2008 at 10:06:06 AM | Custom Property Line Tag
PanTerra
Thanks.
 Would it be possible to do a custom tag?
 PanTerra
Fri, Aug 1, 2008 at 10:25:25 AM | Custom Property Line Tag
Yes ... You can create a tag for almost every REVIT object that has readable properties.  Just edit the tag you already have and save it with a unique name and load back in.
ROUNDING VALUE ON PROPERTY LINE BEARING
Fri, Apr 8, 2016 at 1:13:37 PM
Property line
Tue, Oct 13, 2009 at 5:31:57 PM
How to draw this property line?
Sat, Jan 23, 2016 at 4:48:18 PM
Change unit types for property area tag
Tue, Jun 2, 2009 at 4:49:52 PM
Property line tables on sheet
Tue, Mar 14, 2017 at 1:29:57 PM
Page generation time: 0.6238
