Forums >> Revit Building >> Technical Support >> Unable to print all columns
Thu, Jul 31, 2008 at 10:19:31 AM | Unable to print all columns
Rams
3 Stars: 3 Votes
HI,
When i take printout of my plans all the structural columns are not visible. Few of them are coming. Mostle the SHS column are missing.
Strutural columns are coming from a link file.
I am using Revit Architecture 2009.
Now on the implementation stage....
Thu, Jul 31, 2008 at 11:18:15 AM | Unable to print all columns
4 Stars: 205 Votes
Did you go to VV and see if the "Structural...." are visible (check/unchek)?
Thu, Jul 31, 2008 at 11:23:01 AM | Unable to print all columns
Rams
3 Stars: 3 Votes
Yes they are visible. Only few of them are missing from printout rest all are coming.
Thu, Jul 31, 2008 at 12:05:49 PM | Unable to print all columns
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
What type of view are you printing? From a sheet? Does everything else from the linked file print ? Try changing the view discipline to Coordination? although this ususally only effects walls.
Fri, Aug 1, 2008 at 7:29:11 AM | Unable to print all columns
Rams
3 Stars: 3 Votes
Yes i am printing from sheet.
Changing view disclipline is not making any difference.
For the moment i have drawn 2d lines over it but there should be some solution.
Nyway thanks
Why won't my Filled Regions print?
Tue, Sep 2, 2008 at 3:38:22 PM
Unable to print .prn or .plt files.
Thu, Oct 22, 2009 at 2:51:35 PM
Column Visibility in Callout Detail
Fri, Jul 7, 2006 at 8:17:27 AM
hidden columns
Fri, Mar 26, 2010 at 10:53:36 AM
Showing columns from the floor above
Mon, Jun 9, 2008 at 1:49:48 PM
Page generation time: 1.4536
