Forums >> General Discussion >> Revit Project Management >> Multiple Viewport Titles in same sheet
Wed, Jul 30, 2008 at 6:43:23 PM | Multiple Viewport Titles in same sheet
quinn
I am kinda new to Revit and hit a wall so bear with my newbishness.  I have two different types of titles i need in the same sheet.  One is for the plan viewport which has a bubble.  The other is tied to a legend which has no bubble.  Both are in the same sheet.  The problem i am having is that i have modified both titles and saved them under seperate families that will appear inside the elemental properties option for veiwport type.  What happens is when i select the legend viewport and modify the element to show my title it changes the other viewport title for the plan.  I figured each veiwport was isolated to its own elemental setting but for some reason the viewport seems to change both as global.
What am i missing in this?
Wed, Jul 30, 2008 at 7:16:18 PM | Multiple Viewport Titles in same sheet
quinn
Nm i figured it out you have to duplicate the viewport title then attach the new family to it. GG
Viewport Titles
Thu, Jun 30, 2011 at 8:19:48 AM
Purge unused Viewport Titles
Thu, Aug 30, 2018 at 10:41:49 AM
11
Viewport titles moving
Mon, Nov 10, 2008 at 10:16:48 AM
Viewport title locked. How to unlock?
Tue, Sep 30, 2008 at 3:20:48 PM
Viewport titles - how to modify them?
Sat, Feb 2, 2008 at 9:40:37 PM
Page generation time: 1.2404
