Forums >> Revit Building >> Technical Support >> Hatch Problems
Wed, Jul 30, 2008 at 6:48:09 AM | Hatch Problems
wilson0207
Hi, I cant find anywhere how to solve my problem.
I have a floor plan, and in the hall/landing areas i have a standard horizontal hatch patten to denote the applicable area. The hatch displays fine, but it cuts out my door swings that open out onto the hall/landing areas. Any ideas ?
Wed, Jul 30, 2008 at 6:49:55 AM | Hatch Problems
wilson0207
by the way, I'm using Revit Architecture 2009
Wed, Jul 30, 2008 at 8:15:50 AM | Hatch Problems
You can set your hatch pattern to transparent if it is a filled region.  You don't say where or how you got the hatch.
Wed, Jul 30, 2008 at 8:16:50 AM | Hatch Problems
4 Stars: 205 Votes
Hi, you must "Split" the slab in that area and give them the material and the pattern you want ....
Wed, Jul 30, 2008 at 8:26:45 AM | Hatch Problems
wilson0207
its a filled region,
where do i make it transparent, is it in visibilty graphics,
Wed, Jul 30, 2008 at 8:46:58 AM | Hatch Problems
4 Stars: 205 Votes
Then pick in the Filled region, go to properties, edit-new - background (opaque / transparent)
Wed, Jul 30, 2008 at 8:48:42 AM | Hatch Problems
wilson0207
no way, i thought thay opaque was fixed, nice one man, appreciate it
Wed, Jul 30, 2008 at 8:51:24 AM | Hatch Problems
4 Stars: 205 Votes
Can you put some screenshots with shade to figure out what do you want?
Wed, Jul 30, 2008 at 8:57:14 AM | Hatch Problems
wilson0207
its worked mate, cheers
Wed, Jul 30, 2008 at 9:15:31 AM | Hatch Problems
4 Stars: 205 Votes
You Welcome....
autocad hatch problems
Thu, Dec 14, 2006 at 2:19:07 PM
acad hatch to revit fill conversion problems (revit 2009)
Sun, Sep 21, 2008 at 9:41:31 PM
HATCH 22- REVIT MODEL HATCH
Fri, May 8, 2015 at 3:01:04 AM
Importing Gray to Revit
Fri, May 11, 2012 at 2:47:26 PM
Control Hatch Display
Tue, Jan 10, 2012 at 10:26:34 AM
Page generation time: 2.3178
