Forums >> Revit Building >> Technical Support >> Ground line not consistent
Tue, Jul 29, 2008 at 11:24:15 PM | Ground line not consistent
Sparrow
I am using Revit Architecture 2008.
I want a thick ground line in all my elevation views, so I have gone:
Settings> Object Styles> Model Objects tab> Topography> and set the lineweight cut to 8 (a thick line).
The problem is the thick line only shows up in one elevation - see drawing (bottom elevation shows ground line, top elevation does not).
Can anyone help me to make the ground line appear thick in all elevations?
Tue, Jul 29, 2008 at 11:56:51 PM | Ground line not consistent
timbo89
timbo89 Avatar
4 Stars: 5 Votes
The problem is most likely because your elevation lines don't cut the topo surface. Make sure your elevation line cuts the topo, and this should solve your problem. Also make sure you haven't got "thin lines" turned on.
  • Core 2 Duo E8400 3ghz
  • 756mb Nvidia 9600GSO 256bit
  • 6gb Kingston RAM 800mz DDR2
  • Windows XP Service Pack 3 32-bit
Ground lines
Mon, Jun 13, 2011 at 1:32:56 PM
how to see upper levels dash lines at the ground floor?
Thu, Dec 24, 2009 at 2:26:32 AM
Changing line patterns and weight below the ground line
Mon, Apr 29, 2013 at 7:24:23 AM
Windows showing up gray in consistent colors view.
Tue, Apr 26, 2016 at 11:25:23 AM
13
Rendering Ground Planes showing up when i dont want them to
Wed, May 10, 2006 at 7:14:43 AM
Page generation time: 1.2127
