12 Users Online (10 Members):
Forums >> Revit Systems >> Technical Support >> Titleblocks
38 Posts No Rating |
I'm creating some new title blocks and the built-in label catagories are very limited. I added some new ones with shared parameters and it's working fine on one sheet, but the information isn't transfered over to any new sheets like some of the default lables. Is there some setting I'm missing? Also, I would like to make specific lines not print. Setting the subcategory to <invisible lines> does this but it also makes it invisible in the project. Any help would be much appreciated. Thanks.
First - are your new parameters sheet or project parameters. Sheet are instance ... they will not transfer sheet to sheet. Project are the same on each sheet ... just like the job name... There are no lines except invisible that will not print. But the invisible lines will show when you get close to them.
Yep, that did it. Unchecked "drawing sheet" and checked "project information." Thanks again.
TitleBlocks |
Fri, Dec 8, 2006 at 8:08:02 AM
Titleblocks & Design Options |
Mon, Dec 8, 2008 at 2:06:33 PM
Labels in Titleblocks? |
Mon, Nov 10, 2008 at 3:30:01 PM
Titleblocks |
Mon, Mar 17, 2008 at 3:03:10 PM
Multiline text on Titleblocks |
Sun, Oct 5, 2008 at 8:17:13 PM
