21 Users Online (19 Members):
Forums >> Revit Building >> Technical Support >> Wall wrap at insert problem
I have set my walls so that the exterior wraps at ends and isnerts. The options are ext, int, both, none. I have noticed that revit will only wrap HALFWAY if you say just interiro or exterior. Does anyone know a way around this or if I am missing something. One would think if I selected exterior, that I want the exterior material to wrap ALL THE WAY THE ENTIRE DEPTH OF THE WALL!!! But that would make sense now wouldnt it. I have attached a jpg of the corner in question. As you can see, my exterior siding wraps only to the center of the wall. That corner turn is actually 2 wall openings so that I can get the CMU base and the wall itself to turn at the DF. Any ideas? Thanks.
----------------------------------- Revit Architecture 2010 |
workaround:See attached image. - The red part of the image is actually a small wall mitered to the long black brick wall. Just for the look of it but that doesn't work, construction wise.
Motto: "No Post left behind" |
wall closure wrapping at doors, curtain walls |
Fri, Apr 15, 2011 at 10:50:26 AM
Wall wrap problem |
Sun, Aug 2, 2015 at 11:54:45 AM
Wall Wrap at Insert's Head |
Fri, Aug 8, 2014 at 7:04:01 AM
Wall type wrap |
Thu, Nov 26, 2009 at 3:25:40 PM
Sweep wrap around external walls with opening |
Wed, Jun 25, 2008 at 10:55:55 AM
