Forums >> Revit Building >> Technical Support >> 600dpi maximum rendering for RAC2009???
Tue, Jul 29, 2008 at 10:37:15 AM | 600dpi maximum rendering for RAC2009???
brynn
Is this the highest resolusion one can render an image in 2009?
Tue, Jul 29, 2008 at 12:08:57 PM | 600dpi maximum rendering for RAC2009???
mhans
3 Stars: 10 Votes
Hi,
 It does say Printer resolution, max 600dpi. Most probably it assumes the maximum dpi of your default printer (just a haunch). If you have a high definition printer, make it the default and restart revit and see it it shows. If you don't have more than 600dpi printer, you are safe. You can always increase  your digital dpi in other photo-editing software.
Motto: "No Post left behind"
Wed, Jul 30, 2008 at 6:08:05 AM | 600dpi maximum rendering for RAC2009???
brynn
oh, thanx, what photo-editing software can i use to increase the dpi of an image? any advice?
Wed, Jul 30, 2008 at 12:57:10 PM | 600dpi maximum rendering for RAC2009???
mhans
3 Stars: 10 Votes
You could use Photoshop-image/document  size. Remember, it's no use having a higher dpi that your printer or output device. Say you want to show your products on a digital projector, no matter how high your resolution is if your projector's max is 300dpi, you are limited to that.
Wed, Jul 30, 2008 at 2:55:06 PM | 600dpi maximum rendering for RAC2009???
lunchtrayrider
3.5 Stars: 7 Votes
The idea in revit is that you create an image size in inches and then define the dpi of the image.  if you want more dots then make the image size (in inches) bigger in revit.
I like scooters. and motorcycles.
Wed, Oct 21, 2009 at 10:55:01 AM | 600dpi maximum rendering for RAC2009???
brainatoms
How do you adjust the image size in inches? Printer setup?
The only way I have found to increase the size is to stretch the camera view, which results in distortion.
Wed, Oct 21, 2009 at 11:10:56 AM | 600dpi maximum rendering for RAC2009???
lunchtrayrider
3.5 Stars: 7 Votes
select the crop box, then in the options bar there is an option called size.
you probably want to select scale, then enter a new size.  all done.
Wed, Oct 21, 2009 at 11:26:42 AM | 600dpi maximum rendering for RAC2009???
brainatoms
Thanks... that was easy. Now I only have to wait for three or four days and I'll have a big wonderful rendering.
Wed, Oct 21, 2009 at 11:58:23 AM | 600dpi maximum rendering for RAC2009???
vinnygolfer
4.5 Stars: 4 Votes
hi, if you don't want to wait as long for the rendering, use the custom settings. i found a link on augi that talked about it.
http://forums.augi.com/showthread.php?t=80832&page=2
i go in and change the custom settings.
most of my renderings have gone from 4-8 hours, down to under an hour.
Try to learn at least one new thing every day
Rendering problems
Tue, Sep 18, 2012 at 12:20:01 PM
Pool House Rendering Tutorial
Mon, Dec 15, 2008 at 12:04:02 PM
Keyboard Issue RAC2009
Wed, Jun 18, 2008 at 4:24:58 PM
Rendering Split face block in RAC2009
Mon, Jan 12, 2009 at 10:55:20 AM
Material Properties for Rendering Linked models- RAC2009
Wed, May 21, 2008 at 9:26:12 AM
Page generation time: 0.1455
