Forums >> Revit Structure >> Technical Support >> Adding shading to a solid?
Tue, Jul 29, 2008 at 10:21:06 AM | Adding shading to a solid?
JHerget
I'm trying to create a post so that when a section is taken throught it, it will display one way(see file "5.5pa"Winking and when it is seen from above it will display as file "5.5pb" i have pretty much got it figured out, except I want to make it, so that it will display shaded like in the DWG's attached. I used solid forms to get the lines I needed, so I was hoping I could just add some sort of cut pattern to the solid form, but no the rest of the post, so that only the solid form within it, is shaded. Or perhaps somebody knows a simpler way to accomplish this? Along with the DWG's I am trying to mimmick, I have attached what I have made so far. Thanks in advance
Tue, Jul 29, 2008 at 10:51:23 AM | Adding shading to a solid?
JHerget
Forgot to attach the rfa...
New wall trasparent shading.
Thu, Jun 15, 2017 at 7:46:15 AM
Shading Toolbar
Tue, Jun 22, 2004 at 9:54:36 PM
hatch patterns with shading - reflected ceiling layouts
Fri, Oct 31, 2014 at 6:59:08 AM
Rendering doesn't display textures & shading is black???
Sun, Feb 15, 2009 at 7:35:15 PM
TOO DARK Shading with Edges Revit 2009
Mon, Aug 25, 2008 at 6:57:19 PM
11
Page generation time: 0.3030
