Forums >> Revit Building >> Technical Support >> Cutting an imported solid in plan and section?
Tue, Jul 29, 2008 at 7:29:23 AM | Cutting an imported solid in plan and section?
Sparky
5 Stars: 3 Votes
Ive modeled a flowing form in 3dsMax and exported it as a 3d DWG. After importing into Revit, is anyone aware of a way to cut the solid in section and plan?
Thx for the help guys.
Revit 2009
Tue, Jul 29, 2008 at 7:50:43 AM | Cutting an imported solid in plan and section?
Sparky
5 Stars: 3 Votes
here is an image of what ive done in 3dsMax for interest sake
Tue, Jul 29, 2008 at 7:59:08 AM | Cutting an imported solid in plan and section?
Read your help on what is cutable.  The import is not.  You may be able to import it into a family that is.
Tue, Jul 29, 2008 at 9:45:49 AM | Cutting an imported solid in plan and section?
KingRevit
4 Stars: 12 Votes
yes i believ the best way is to import it into a mass family then import that
Solid Sweep Not Cutting in Section
Mon, Dec 18, 2006 at 2:06:34 PM
Cutting Sections through imported Autocad 3d objects
Fri, Dec 18, 2009 at 12:39:53 PM
Cutting a 3D view on plan
Tue, Jun 17, 2008 at 8:47:51 AM
Section or elevations not cutting imported dwg's
Fri, May 9, 2008 at 3:30:44 PM
Section cutting a family?
Thu, Jan 11, 2007 at 3:30:49 AM
Page generation time: 1.2736
