Forums >> Workflow & Implementation >> API & Third Party Apps >> Cut / Join - Geometry (api)
Tue, Jul 29, 2008 at 2:07:19 AM | Cut / Join - Geometry (api)
mamanari
Hi All:I need to activate cut geometry (or Join Geometry)from the api.(like in Tools-->Cut Geometry ;manual)my aplication sometimes take two elements (for example 2 walls)and change their width (or a little change in the geometry like Length) so they enter one each-other and then I get a few Warnings.if I manualy use the Tools-->Cut Geometry it fix it.but I dont want to this manualy,and I dont know how to activate this via api or to fix it in any other way.if anyone has any suggestion I will be more then happy to read it.Thanks a lotArik
Parallel walls join geometry do not cut opening
Fri, Jan 31, 2020 at 1:32:48 PM
Revit Structure 2008 SP2: Join Geometry on differnet beam families
Wed, Sep 19, 2007 at 11:58:38 AM
join geometry problem
Wed, Jan 27, 2010 at 5:53:31 AM
Cut Geometry in 3D
Sun, Aug 9, 2015 at 10:52:45 PM
Revit API returning error message referring to Revit Geometry
Wed, Feb 16, 2011 at 10:54:07 AM
Page generation time: 2.0054
