Forums >> Community >> Newbies >> CLOSED LOOP?
Mon, Jul 28, 2008 at 6:53:05 PM | CLOSED LOOP?
citroen
What does it mean that "an extrusion must be a closed loop"?  Seems obvious but the answers are not in the tutorial nor the help desk.
Tue, Jul 29, 2008 at 7:28:32 AM | CLOSED LOOP?
The extrusion must be fully enclosed in a boundry that is defined by linework.  Lines must not cross ... no lines can exist other than those that define the boundry.
Mon, Dec 30, 2019 at 2:55:23 PM | CLOSED LOOP?
prashantabs
prashantabs Avatar
Sometimes the closed loop does not form even if it is closed. The work around to this is to create a new element similar to the one you are creating and then select the lines of the old one. This worked for me nicely. Hope it helps others who also encountered similar problems.
Parapet Profile Closed Loop Error
Fri, Mar 8, 2013 at 12:12:04 PM
Revising a profile
Wed, Aug 20, 2008 at 1:22:56 PM
Creating and Loading Profiles
Tue, Apr 8, 2008 at 12:19:55 PM
Parking on Grass
Fri, May 8, 2009 at 3:20:20 PM
pick walls to create floor
Tue, Apr 3, 2012 at 11:34:38 AM
Page generation time: 0.0293
