8 Users Online (6 Members):
Forums >> Revit Building >> Technical Support >> new wall type creation isn't unique?
17 Posts No Rating |
trying to create new wall type with green tile instead of red, i duplicated the red tiled wall renamed it to green tile wall changed appearance of finish of the red tile component to green result was both walls now show green tile, intent was to keep the original tile color as red with the new wall showing green what step did I miss?
THE TWO WALLS SHOWN ARE THE SAME WALLS FROM PREVIOUS ATTCHMNT. WHY IS IT THAT WHEN I CHANGE THE THICKNESS OF ONE WALL IT CHANGES ONLY THE WALL THAT WAS SELECTED BUT, WHEN I CHANGE THE COLOR OF THE CERAMIC TILE (ALSO IN THE "EDIT ASSEMBLY" DIALOGUE BOX) IT NOT ONLY CHANGES THE COLOR OF THE TILE IN THE SELECTED WALL BUT, ALSO THE WALL THAT WAS NOT SELECTED FOR EDIT.
found the following posting, thank you sdbrownactive Joined Fri, Dec 12, 2003164 Posts YOu need to change the material assignments in each wall type to be diff. from each other.
Wall Type creation via API -H-E-L-P. |
Tue, Jun 10, 2008 at 10:01:53 AM
Making your first wall type assembly |
Wed, Apr 26, 2006 at 3:51:42 PM
Wall tags don't show type mark |
Thu, Jun 22, 2006 at 12:29:47 PM
"Revit Help Image" Wall Creation |
Thu, Jan 15, 2009 at 1:28:25 AM
editable chart |
Thu, May 2, 2013 at 7:43:00 AM
