Forums >> Revit Building >> Tips & Tricks >> Advanced Internal Lighting
Sun, Jul 27, 2008 at 6:53:09 AM | Advanced Internal Lighting
JustinT
It's always been the case that with a few little tweaks you can improve your final rendered image.. and here's another one for Revit 2009 users.But be warned this will increase the render time... so be patient :o)For advanced lighting quality in interior views, you can enable daylight portals, if needed. Daylight portals improve the quality of light that shines through windows, doors that contain windows or glass, and curtain walls.The images below shows firstly on the left what the rendered image looks like without daylight portals enabled and then on the right with them on:By default, daylight portals are turned off. If a rendered image shows sunlight reflecting off surfaces, and the sunlight is speckled or splotchy, you may be able to improve the image by turning on daylight portals.To activate or switch on the Daylight Portals, Edit the Settings under Quality, within the Render dialog box... scroll down until to get to the Daylight Portal Options and then put a tick in windows, doors and curtain walls.Now just render your scene and go for a long lunch break.
Justin
www.revitup.co.za
Thu, Sep 4, 2008 at 3:53:24 PM | Advanced Internal Lighting
cganiere
cganiere Avatar
Thanks for the tip.
Christopher Ganiere, NCARB, LEED AP
www.developmentone.net
Skype: ArchitectCRG
Render Internal Lighting Issue
Sun, Nov 7, 2010 at 8:04:47 PM
Lighting Family
Thu, Jan 24, 2008 at 3:54:03 PM
the most advanced parametric family???
Thu, Sep 8, 2005 at 10:02:36 PM
Revit Internal Parameters..?
Tue, Sep 14, 2010 at 10:51:15 AM
Rendering And Light Settings Revit 2009
Sun, Jul 19, 2009 at 9:24:26 PM
Page generation time: 0.0694
