17 Users Online (15 Members):
Forums >> Revit Building >> Technical Support >> propagate extents
42 Posts No Rating |
Why some of my grid lines are not possible to propagate to all levels?i put up the grid line system in level 1 and then i set the vertical levels (around 12) and then revit surprised me nasty, not allowing to propagate all my grid lines to all my levels.
I got it. In an elevation view one have to see the grid lines (datums) as vertical lines.Then simply make sure that the grid line intersects all the levels in the elevation view and you will be able to propagate it to all the levels. A bit of a problem is when the grid line is not perpenidicular to the elevation plane.I have some grid lines at 15 and 75 angles, cause of the irregular shape of the building. In such a case you have to make copies of some elevations (in a plan view) and rotate them so that they face the grid lines perpendicularly. Now you can go to the new rotated elevation view and observe and control these grid lines.
grid lines resetting unitentionally |
Wed, Feb 17, 2010 at 6:58:36 PM
grid lines question revit 2009 |
Tue, Nov 25, 2008 at 11:02:14 AM
DOES ANYBODY HAVE A GOOD WORK AROUND FOR GRID LINES? |
Mon, Jun 15, 2009 at 1:14:15 PM
PROPAGATE EXTEND |
Thu, May 21, 2015 at 10:16:24 AM
Grid lines moving together in different floor plans |
Mon, Sep 20, 2010 at 9:10:52 PM
