Forums >> Revit Building >> Technical Support >> DIMENSIONS
Fri, Jan 23, 2004 at 1:31:28 PM | DIMENSIONS
Bimman
Bimman Avatar
1 Stars: 2 Votes
WHEN RUNNING A STRING OF DIMS CAN YOU TURN OFF DIMS SAY THAT SHOW INTERIOR WALL THICKNESS. SINCE ALL MY INTERIOR WALL DIMS ARE 3 1/2" IT GETS A LITTLE CLUTTERED IN TIGHT AREAS ON THE PLAN. WHAT I HAVE BEEN DOING THUS FAR IS JUST RUNNING SINGLE DIMS ACROSS ROOMS AND STOP SKIP THE WALL AND START ON THE OTHER SIDE TO THE NEXT ROOM AND SO ON THROUGH OUT THE ENTIRE FLOOPLAN.
PWD
Fri, Jan 23, 2004 at 1:54:14 PM | RE: DIMENSIONS
sfaust
Sorry if I misunderstand, but why dimension both sides of the wall? The width is already determined by the wall construction, so location of one side should be enough for a contractor to build off of...
Fri, Jan 23, 2004 at 1:58:07 PM | RE: DIMENSIONS
Bimman
Bimman Avatar
1 Stars: 2 Votes
not that both side are dimensioned. but if i am running continious string of dimms through a floorplan rather than having to dim each room seperatly wall to wall i just continue it through the whole thing. i dim to core facce rather that cenerline so when i due this i get a 3 1/2 measurement for each dividing wall. i,m just trying to eliminate the 3 1/2" dim.
PWD
Fri, Jan 23, 2004 at 5:29:23 PM | RE: DIMENSIONS
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
the only way I know of doing this is the method you described
Hiroshi Jacobs
EQ Display in dimensions Revit 2009
Tue, Mar 23, 2010 at 3:28:36 PM
Isometric Dimensions in Drafting Views (details)
Fri, Sep 28, 2012 at 3:13:08 PM
Changing Dimensions
Mon, Feb 7, 2011 at 9:02:52 AM
Disappearing Dimensions
Mon, Aug 19, 2013 at 12:33:56 PM
temporary dimensions disappeared
Wed, Apr 25, 2012 at 10:37:51 AM
Page generation time: 0.4255
