Forums >> Community >> Newbies >> Object parameters
Fri, Jul 25, 2008 at 7:58:13 PM | Object parameters
StevenTrama
Can I stretch an object for example base cabinet and have new doors insert as it gets longer?
 Can I add a dollar value to object like casework and extrusions and have that value increase as the object gets longer?
Sat, Jul 26, 2008 at 5:09:21 AM | Object parameters
4 Stars: 205 Votes
You can edit one family, change the parameters (lenght, height,etc) like do you want and save with another name to don't loose the first one...
Sun, Jul 27, 2008 at 8:27:36 PM | Object parameters
StevenTrama
Thanks Typhoon for your feed-back, I understand how to make new object types, my question is a little more complex,
Q is how do I make a type (for example base cabinet) display a new door as I strectch the object,
So in the scenario where I start with a 6oomm wide base cabinte with one door, can I stretch this object (while in a model view) nad have a second door detailed as I stretch the original object to 1000mm?
Mon, Jul 28, 2008 at 10:26:27 AM | Object parameters
TABEST
4 Stars: 4 Votes
Your gonna have to use arrays mixed with functions to control this ability, I had to do the same thing, and it is a pretty complex family.
Mon, Jul 28, 2008 at 12:53:06 PM | Object parameters
4 Stars: 205 Votes
Yeah, TABEST is right, you must create a family with some arrays to control that, it's a Complex (simple) family to do...
OBject with adjustable parameters
Fri, May 23, 2008 at 11:26:01 AM
Dynamic object parameters
Mon, Jul 28, 2008 at 5:51:13 AM
Scheduling shared parameters of nested famiies?
Sun, Apr 26, 2009 at 1:56:12 PM
Help with dwf visible parameters
Mon, Aug 23, 2010 at 2:41:35 PM
Linking Object in detail item to multiple parameters.
Thu, Sep 20, 2012 at 1:05:25 PM
Page generation time: 0.2368
