14 Users Online (12 Members):
Forums >> Revit Building >> Tips & Tricks >> Turn off view scales
17 Posts No Rating |
This is my problem. I create my legends at 1:1 scale and then place them on a sheet with a drawing at 1/4" scale and then the title block changes to "As Indecated". Can I make it so that they are not perceived as another drawing? Thanks, Doug
Hi, Revit is so wise to know that your scale varies (if you have multiple view) on your titleblock. What I could not understand with your problem is why you would want your legend scale different from your plan/elev/sec/detail view? You can edit your legend text to have similar scale with your view, just adjust the text height. Or, make a similar titleblock with blank scale that you can just type in as text, special for this sheet.
Modify list of view scales |
Tue, Aug 14, 2007 at 12:00:44 PM
Turn off a category in multiple views - efficiently |
Thu, Jan 8, 2009 at 3:04:59 PM
Multiple sheets from same floor plan view with different scales? |
Fri, Aug 1, 2008 at 12:01:43 PM
Default value "Hide at scales..." |
Mon, Mar 3, 2014 at 9:17:22 AM
Different Scales on Titleblock |
Tue, Aug 7, 2012 at 8:04:29 AM
