Forums >> Revit Building >> Technical Support >> Going from trial version to network install - can't pull a license
Fri, Jul 25, 2008 at 9:06:16 AM | Going from trial version to network install - can't pull a license
kimeicher
Anyone know of any problems with installing a network license after a trial version has previously been installed?
I am trying to get Revit Arch. 2009 running for a customer.  All of their computers are able to pull a network license, EXCEPT for one computer.
All communication is good between the server and this client machine.  We've pinged the server name and IP address and pinged from the server to the client (name and IP address).  All that was good.  The client is not remotely located.  All firewalls are turned off and security software disabled.
The only thing that we are aware of, that's different about this computer vs. others, is that a trial version of Revit was initially installed.  During the trial period, the client tried to install his network deployment.
We've uninstalled (and used the windows clean up utility to do a CLEAN uninstall.  When the deployment opened in demo mode, we tried a network install from disk.
Revit continues to open in demo mode on this computer!  I'm at a loss.
~Kim
Edited on: Fri, Jul 25, 2008 at 9:08:05 AM
Edited on: Fri, Jul 25, 2008 at 9:09:25 AM
Wed, Sep 17, 2008 at 6:11:37 PM | Going from trial version to network install - can't pull a license
cganiere
cganiere Avatar
Reformat, reinstall windows and start over. Autodesk has a very aggressive copy protection scheme.
Alternatively call Autodesk and have them walk you through it.
Christopher Ganiere, NCARB, LEED AP
www.developmentone.net
Skype: ArchitectCRG
Network License Manager
Tue, Oct 9, 2007 at 8:27:06 PM
Trial Version
Tue, Nov 15, 2011 at 3:21:47 AM
LOST NETWORK LICENSE
Fri, Oct 15, 2010 at 2:36:36 PM
Use 'License Tranfer Utility' for Temporary, Telecommuting Revit Drafters?
Wed, May 12, 2010 at 3:46:54 PM
Revit will only let me install Design Review
Wed, Nov 9, 2011 at 10:46:03 AM
Page generation time: 0.3617
