13 Users Online (11 Members):
Forums >> Revit Building >> Technical Support >> Decal mapping and rendering
1 Posts No Rating |
Hello, I'm using Revit 2009. I've placed 10 decals on ten video monitors. But when i render the view. All i get is two images. 6 of one and 4 of another. What went wrong? Any help, anyone?
Hey, for every picture you want to use, you need to create a new decal ie picture "a" will be decal "a", picture "b" will be decal "b" and so on. Check to see if your decal's are all the same, and adjust the settings accordingly to produce new ones. You should have 10 seperate decals in the type selector, and they should all have different pictures. When you created them, you may have duplicated them without changing the actual photo that will appear. Click on the decal, go to element properties-->edit/new-->and click edit next to decal attributes. Make sure the file location of each decal is different, otherwise all decals will be the same. Hope this helps =)
Edited on: Thu, Jul 24, 2008 at 7:56:38 PM
- Core 2 Duo E8400 3ghz
- 756mb Nvidia 9600GSO 256bit
- 6gb Kingston RAM 800mz DDR2
- Windows XP Service Pack 3 32-bit
Decal rendering |
Sun, Nov 9, 2008 at 4:02:33 AM
Decal Changing Sizes in Rendering |
Thu, Jul 25, 2013 at 1:56:16 PM
Decal is not rendering |
Wed, May 13, 2015 at 10:36:56 AM
decal not working |
Wed, Jan 20, 2010 at 12:30:30 PM
Material Mapping on Families |
Sat, Nov 4, 2017 at 7:01:14 AM
