28 Users Online (26 Members):
Forums >> Revit Building >> Technical Support >> changing base line elevation
42 Posts No Rating |
I built my project with the 1st Floor level at 0'-0" and need it to be 100'-0", with the other levels corresonding to the extra 100'. I can't find a global setting that tweaks it all. Anyone run into this? Thanks!
14 Posts No Rating |
Run a dimension string between all levels and click the lock on each dimension. Change the first floor to 100' and every other floor will remain the locked distance from the first level.
try this http://www.revitcity.com/forums.php?action=viewthread&thread_id=4646 HTH
changing base project elevations |
Mon, Jun 22, 2009 at 4:15:15 AM
Can Revit show base elevation line where it cuts topography? [ 1 2 ] |
Fri, Dec 2, 2011 at 1:53:57 PM
20
Elevation Line Extensions |
Mon, Apr 30, 2012 at 8:08:08 AM
Isolated Foundation atching to column base: Revit 2010 |
Thu, Jun 25, 2009 at 1:59:29 AM
topography elevation base |
Tue, Mar 27, 2007 at 11:34:14 PM
