Forums >> Revit Building >> Technical Support >> how to angle end of wall
Wed, Jul 23, 2008 at 1:16:17 PM | how to angle end of wall
jeffrb25
I have a wall that has no adjoining wall at its end and I want to angle that corner.  Also, how can you add a wall sweep reveal to the end face of wall so that the exterior reveal wraps to face of wall end?
Wed, Jul 23, 2008 at 1:28:19 PM | how to angle end of wall
If you are saying that you want to angle the wall in plan (you are not clear), just add a vertical sweep ... reveal or positive - up to you.
No reveals will wrap the ends of a wall.  To acccomplish both of your questions, create an in-place wall family at the end of your wall and join geometry with your wall.
Wed, Jul 23, 2008 at 1:37:15 PM | how to angle end of wall
jeffrb25
Yes in plan, I want to chop the corner of the wall at an angle.  Sounds like a vertical reveal could work.  The wall extends into the diagonal cooridor which wants to share thate diagonal angle.
Regarding the reveal at wall end I will try the in-place wall and join geometry to wrap the exterior reveal.
 Thanks for your help
Vertical reveals to angle wall end
Mon, May 11, 2009 at 11:36:00 AM
Wall end at an angle
Mon, Apr 14, 2014 at 4:26:52 PM
Angle curtain wall
Thu, Jan 24, 2013 at 3:00:57 PM
create a wall sweep on an angled wall (gable end wall) (2017)
Wed, Aug 3, 2016 at 2:29:53 PM
Curtain wall to wall at an angle
Tue, Jun 12, 2018 at 2:38:49 PM
Page generation time: 1.5959
