Forums >> Community >> The Studio >> About AccuRender
Sat, Apr 16, 2005 at 3:24:53 PM | About AccuRender
justinmthomas2003
Is AccuRender made by Autodesk? Or could it be made by other company? If so, could it be possible if we could add other Render software to Revit?
Sat, Apr 16, 2005 at 4:04:05 PM | RE: About AccuRender
TomDorner
4.5 Stars: 25 Votes
Accurender is made by Robert McNeel & Associates. It is a stand alone product that can be used to render various formats. The version included in Revit is a scaled down version. Autodesk makes a rendering package called Viz. Revit and Viz now play well together. Check out the Autodesk website for more information. HTH Tom Accurender link: http://www.accurender.com Post edited on 2005-04-16 16:05:07
Sat, Apr 16, 2005 at 4:52:41 PM | RE: About AccuRender
justinmthomas2003
But what if I want to bring in VRay, will that not be possible?
Sun, Apr 17, 2005 at 9:29:43 AM | RE: About AccuRender
Arnel Aguel
Vray is a plug-in renderer for viz or max for fast and high quallity render. It will be the same process when using with viz or max only you still have to export the 3d revit file to dwg then file link it to viz/max. In viz/max you can use the built renderer such us scanline renderer, radiosity or mental ray. if you have purchase Vray then you can use it as well but it will still be the same process. Furthermore take note that there is a revit-viz plug-in that you can use to export your material x-data from accurender and that can be read and open in viz. For max 7.5 and viz 2006 there is no need for the plug-in it is already built-in. Make sure that you have this plug-in otherwise you will be in a mess everytime you update your model.
Thu, Nov 16, 2006 at 4:16:18 AM | About AccuRender
nelioabreu
does anybody know where i can find Vray for Viz? Vray version for studio max work with viz?
Accurender ground cover
Wed, Feb 22, 2006 at 2:08:03 PM
Accurender
Fri, Dec 1, 2006 at 6:34:49 AM
Adding new materials to accurender library
Thu, Nov 19, 2009 at 5:44:18 AM
Accurender nXt for Revit. Alpha version available.
Wed, Apr 8, 2009 at 10:05:55 AM
ACCURENDER
Mon, Feb 19, 2007 at 3:16:52 PM
Page generation time: 0.8818
