11 Users Online (10 Members):
Forums >> Revit Building >> Technical Support >> HVAC Diffuser will not print
42 Posts No Rating |
I have currently inserted a HVAC Diffuser, the family I don't think it was modeled properly, since it is made only with model lines. It shows perfectly in the view, but when you print, they are not showing, even in PDF, previews anything... Has anyone had that same problem? Thanks
When you print that sheet or what ever you are printing that shows that HVAC diffuser, use the raster processing option n of vector processing. HTH
Edited on: Wed, Jul 23, 2008 at 12:25:29 PM
WOW! Thanks! It fixed it, but here is another question. Are there any drawbacks to the raster processing as opposed to the vector? things like processing time? or image quality?
Yes, rastering takes more time to pring than does vector. Other than time, there is no drawback, so I wouldn't use raster unless you have to get things to show, as in this case.
HVAC diffuser question |
Thu, May 17, 2012 at 9:16:14 AM
2D diffuser transparency |
Wed, Jan 8, 2014 at 8:31:36 AM
12
Linear Air Diffuser |
Sat, Jun 11, 2016 at 12:58:53 AM
Diffuser |
Tue, May 29, 2012 at 8:24:46 PM
REVIT MEP, Diffuser Airlfow Parameter isssue |
Mon, Jun 21, 2010 at 1:46:22 PM
