Forums >> Revit Building >> Technical Support >> RAC2009 - > green lines in 3d view
Tue, Jul 22, 2008 at 12:53:52 PM | RAC2009 - > green lines in 3d view
Rasmus55
Hey...
 Well i looked over some old posts that had the same topic, but they dont help me. Can anyone tell me how to get the green line gone from my 3d view? See the SS below.
Thx in advance..
Tue, Jul 22, 2008 at 2:05:26 PM | RAC2009 - > green lines in 3d view
MarkBryan
Did you try turning off all lines, more specifically room seperation lines?
Tue, Jul 22, 2008 at 6:43:23 PM | RAC2009 - > green lines in 3d view
Rasmus55
Yea all lines is set to black and i tryed to uncheck them in Visibility/Graphic Override.. And i still got green lines... : /
Wed, Jul 23, 2008 at 5:45:58 AM | RAC2009 - > green lines in 3d view
Look in your settings - object styles.  Yon may have something set there.
Wed, Jul 23, 2008 at 8:16:09 AM | RAC2009 - > green lines in 3d view
KingRevit
4 Stars: 12 Votes
looks like you have a graphics override turned on
Fri, Jul 25, 2008 at 12:12:36 AM | RAC2009 - > green lines in 3d view
timbo89
timbo89 Avatar
4 Stars: 5 Votes
Hey, did you create a group and then save it externally? I did that and my lines turned green like yours, and I was wondering have you found out how to fix it?
  • Core 2 Duo E8400 3ghz
  • 756mb Nvidia 9600GSO 256bit
  • 6gb Kingston RAM 800mz DDR2
  • Windows XP Service Pack 3 32-bit
Fri, Jul 25, 2008 at 4:25:42 AM | RAC2009 - > green lines in 3d view
Rasmus55
Nope i didnt fix it in revit, i fixed it AI when i fixed my final outline. I tryed to make all my lines black in object style, but they will still be green. Make a view with the camera in view tool bar, and adjust that, and it could be gone, it think, didnt try it tho.
Fri, Jul 25, 2008 at 6:12:31 AM | RAC2009 - > green lines in 3d view
Did you use the line tool and pick a model line?  The default model line "Line" is green if I remember correctly.
Thu, Aug 21, 2008 at 10:22:35 AM | RAC2009 - > green lines in 3d view
everist
3 Stars: 2 Votes
Did you ever figure out how to get rid of the green outlines in your 3d view?
Thu, Aug 21, 2008 at 11:03:55 AM | RAC2009 - > green lines in 3d view
LIZARD2806
3.5 Stars: 7 Votes
Try going into your View Properties, select Advanced Model Graphics, and make sure that the Silhouette Style is set to <none>.  If it is, try setting it to Medium Lines or some other such line style that you are sure is black.  Please let me know if it works.
Cheers.
Thu, Aug 21, 2008 at 11:12:33 AM | RAC2009 - > green lines in 3d view
everist
3 Stars: 2 Votes
I started this particular project in version 2008. version 2009 by default sets slab outlines to green. When I created a new file in 2009, the green outlines threw me off. Simple fix as usual.
3D component strangeness, green lines and not visible in 3d
Fri, Aug 8, 2014 at 7:28:02 AM
green model lines
Fri, Sep 9, 2016 at 11:36:06 AM
Green object lines
Mon, Sep 12, 2016 at 9:40:03 AM
Edit Cut Prolie Green Lines?
Sun, Apr 11, 2010 at 8:25:44 AM
RAC2009 - color schemes don't show up
Mon, Jun 24, 2013 at 9:04:35 AM
Page generation time: 0.8010
