Forums >> Revit Building >> Technical Support >> RAC2009 Beam system
Mon, Jul 21, 2008 at 9:21:54 PM | RAC2009 Beam system
timbo89
timbo89 Avatar
4 Stars: 5 Votes
Hey, i created a beam system by going to the structural tab-->beam system. The internal beams are behaving correctly, but my end beams don't show up. The lines with the black line around them don't have any beams on them. Am I missing something, or can't beams be placed on the end? I tried changing the justification to end, centre and beginning, but that did nothing. Any help would be greatly appreciated =) Cheers.
Edited on: Mon, Jul 21, 2008 at 9:27:40 PM
  • Core 2 Duo E8400 3ghz
  • 756mb Nvidia 9600GSO 256bit
  • 6gb Kingston RAM 800mz DDR2
  • Windows XP Service Pack 3 32-bit
Tue, Jul 22, 2008 at 11:16:14 AM | RAC2009 Beam system
broncos4life
3.5 Stars: 11 Votes
From my understanding the beam systems should be used for filler beams.  The beams at both ends of a "beam system" would not be considered part of the beam system.  So if you have your structure all build and have all your columns in and your transfer beams that transfer the loads directly to the columns, then you use the beam systems tool to fill in beams between the beams that transfer the loads directly to the columns.
HTH
Edited on: Tue, Jul 22, 2008 at 11:16:33 AM
Beam system height VS. Beam height error
Fri, Jan 22, 2016 at 4:31:20 PM
Adding a beam system issue
Sun, Jun 15, 2014 at 2:58:10 PM
Beam System Tag
Fri, Aug 14, 2009 at 3:09:33 AM
Schdule of Beam System
Tue, Jan 4, 2011 at 5:45:12 AM
beam system
Thu, Oct 15, 2015 at 7:32:17 AM
Page generation time: 1.6590
