Forums >> Revit Building >> Technical Support >> Door types on schedules
Mon, Jul 21, 2008 at 10:01:55 AM | Door types on schedules
aaronkennedy
Is there a way to adjust the door types on the schedule to show feet and inches in one column instead of just inches or two different categories of height and width?
Thank you,
AAron
Mon, Jul 21, 2008 at 11:30:44 AM | Door types on schedules
lunchtrayrider
3.5 Stars: 7 Votes
do you have an image of what is going on?
I like scooters. and motorcycles.
Mon, Jul 21, 2008 at 11:55:52 AM | Door types on schedules
aaronkennedy
I do not yet but I can describe it pretty well.  I can put in a column for width and a column for height.  Is there a way to combine them?  I want it to read in feet and inches   3'-0" x 7'-0" in one column.  And I do not want the type setting where it just has inches.
Thanks
Mon, Jul 21, 2008 at 12:16:24 PM | Door types on schedules
lunchtrayrider
3.5 Stars: 7 Votes
I don't think that you'll be able to combine them.  Doors have seperate parameters for height and width and schedules really only read 1 parameter per column.  You could name the door in feet and inches and list that but since its not parameter driven that would be frowned upon.  Your best sticking to a seperate column for height and width.  They should be already listing out in feet and inches anyway.
Thu, Jul 24, 2008 at 11:49:24 AM | Door types on schedules
aaronkennedy
Thanks Rider,  You confirmed what I thought.
 I appreciate it.
AAron
Fri, Jul 25, 2008 at 6:26:09 PM | Door types on schedules
Martha
I asume you don't want to use another parameter (like "description", for example) and write the size as you wish. Later, you can modify the head of the column with another name.
I hope you understand my english, and I don't know if I understood your thread correctly.
Regards.
Fri, Jul 25, 2008 at 6:38:32 PM | Door types on schedules
lunchtrayrider
3.5 Stars: 7 Votes
The size of the door in a door schedule should be parameter tied and not based on a description.
Door and Window types
Thu, Nov 23, 2017 at 11:19:52 AM
Schedules: Ie Door schedules!
Fri, Jul 11, 2014 at 2:58:22 PM
Schedules/Quantities
Tue, Dec 20, 2005 at 10:05:21 AM
Nested Door Families and Door Schedules
Mon, Nov 8, 2010 at 2:56:46 PM
How to Print Large Door Schedules Revit 2009
Wed, Jan 21, 2009 at 12:28:45 PM
Page generation time: 0.8395
