Forums >> Revit Building >> Technical Support >> floor plan view not available for underlay
Fri, Jul 18, 2008 at 3:16:24 PM | floor plan view not available for underlay
rquist
I have a "first floor - new construction"  floor plan view that I can pull onto a drawing sheet but,  it does not show up in the available underlay views.
It's time to draw the foundation and I want to "trace" the first floor.
Seems like I should know this one.
Fri, Jul 18, 2008 at 3:34:11 PM | floor plan view not available for underlay
rkitect
rkitect Avatar
4 Stars: 29 Votes
You can only bring in Levels as underlays, not individual views.  This is because you have views that can be totally unrelated to the model (ie: drafting views).  To prevent coordination issues, they make it so that you have to bring in everything that is visible on the level.  The visibility should be the same for the level you bring in as the view you are working in (so if you have walls turned off in your view, the walls will be off in the underlay as well).
Underlay.... problems
Tue, Jul 31, 2007 at 11:36:03 PM
Second Floor Plan w/ First Floor Underlay
Mon, Jun 19, 2006 at 12:10:25 PM
REVIT 2015 - Underlay: EXPORT?
Tue, Aug 5, 2014 at 2:54:54 PM
Underlay in Site Plan
Fri, Aug 6, 2010 at 8:26:01 AM
underlay
Mon, Aug 11, 2008 at 6:18:01 PM
Page generation time: 0.9679
