Forums >> Revit Building >> Technical Support >> Is it possible to show ROOF OUTLINE on FLOOR PLAN?
Fri, Jan 23, 2004 at 3:15:15 AM | Is it possible to show ROOF OUTLINE on FLOOR PLAN?
avenir
1 Stars: 1 Votes
Anyone out there know if it's possible to show the roof out-line on the floor plan? I've tried without results. Thanks in advance. Dave
Fri, Jan 23, 2004 at 5:40:20 AM | RE: Is it possible to show ROOF OUTLINE on FLOOR PLAN?
Steve_Stafford
5 Stars: 2 Votes
Linework command and view range: Temporarily change the view range on the plan you want the roof dashed in on to a value that will show the roof as much as you need. So, for eaves only you don't need to set it as high as if you want valleys and ridges for example. While it is changed, use the linework command to change the roof lines to "overhead", then set view range back to what it was. The roof will now be dashed in over the plan. If you change the sketch of the roof you'll need to redo the linework. This is true for ceilings too... However if you move walls that have an association with the roof (like from using the pick walls option to create the roof sketch or by attaching a wall to a roof), the linework will remain intact and move accordingly. Post edited on 2004-01-23 05:40:52 Post edited on 2004-01-23 05:49:10
Fri, Jan 23, 2004 at 1:07:27 PM | RE: Is it possible to show ROOF OUTLINE on FLOOR PLAN?
Admin
admin
Admin Avatar
3 Stars: 4 Votes
Ignore this... I'm checking for a forum bug that Steve reported.
Pierced Media, LC
Fri, Jan 23, 2004 at 9:44:26 PM | RE: Is it possible to show ROOF OUTLINE on FLOOR PLAN?
Steve_Stafford
5 Stars: 2 Votes
Never mind this post, this is a response to the response
Fri, Jan 23, 2004 at 9:54:42 PM | RE: Is it possible to show ROOF OUTLINE on FLOOR PLAN?
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
forget it...this is just a response to the response's response.
Hiroshi Jacobs
Fri, Jan 23, 2004 at 11:21:47 PM | RE: Is it possible to show ROOF OUTLINE on FLOOR PLAN?
Admin
admin
Admin Avatar
3 Stars: 4 Votes
haha...all very funny.
HOW TO SHOW SUBREGION OUTLINE ON FLOOR PLAN
Mon, Jul 11, 2011 at 7:32:06 PM
Roof doesn't show up on floor plan
Wed, Feb 6, 2019 at 10:43:46 AM
Best way to show outline of building under roof on site plan
Mon, Apr 13, 2015 at 7:08:27 PM
RAC2008 - Building footprint on Roof Plan
Wed, Aug 15, 2007 at 11:49:47 AM
Ceiling Fixtures showing up on Floor Plans
Thu, Feb 7, 2013 at 7:31:58 AM
Page generation time: 0.8546
