22 Users Online (20 Members):
Forums >> Revit Building >> Tips & Tricks >> Two point perspective?
Any trick? Thanks
Camera tool, no trick... just use the camera tool.
I can't find anything that change to two point perspective; the only one is the Perspective button but appears as Parallel Projection view.
All cameras have the ability to have the focal length changed, causing them to appear to be anything from 2 point to 3 point perpectives. If you have a view that appears to be 1 point perspective, it's because the camera is looking at the object in such a manner to make it appear like a 1 point perspective.
Sorry wrong post, must be for 3ds max users  Only wide lines appears with focal length changes????
4 Posts No Rating |
use the camera on the view tab... position it on the plan.. and there you have your two point perspective. press Shift+click wheel of mouse + rotate the model inside the box. and there you have your three point perspective. for further instructions.. press f1..
SIlent,...Solitary,...Empty |
0 Posts No Rating |
Old thread, but I can help.
In the properties, make sure the 'Eye Elevation' & 'Target elevation' have the same value. The value is subjective depending on how do you want to level it. Its doesnt matter if its too high or low, you can get the right composition after modifying the crop of the view.
0 Posts No Rating |
use the camera tool!
One point perspective section |
Thu, Jun 21, 2007 at 8:17:52 PM
Perspective Problem |
Fri, Jun 26, 2009 at 12:13:43 PM
Two Point Section Perspectives |
Fri, Feb 24, 2017 at 8:19:15 AM
perspective angle |
Thu, Mar 29, 2012 at 7:43:10 AM
Distorted Perspective |
Wed, May 21, 2008 at 11:08:56 AM
