Forums >> Revit Building >> Technical Support >> paint fill pattern complete image reference
Fri, Jul 18, 2008 at 11:16:01 AM | paint fill pattern complete image reference
rquist
is there a "document" that shows what all of the paint fill patterns look like w/o scrolling through the entire list?
Fri, Jul 18, 2008 at 3:55:54 PM | paint fill pattern complete image reference
rkitect
rkitect Avatar
4 Stars: 29 Votes
Well, the matierials that show up in the drop down box do not determine the surface patterns that show up.  Instead the materials have a fill pattern associated with them which can be changed by you.  The closest you're goign to get to seeing what the patterns looks like is by going to Setting > Fill patterns.  Note there are Model and Draft patterns, either of which can be associated with the materials available in the drop down box for the paint tool.  You can see which surface pattern is associated with which material by goign to Settings > Materials and looking through the materials in that list.
HTH!
color scheme/fill pattern
Mon, Jul 9, 2012 at 4:56:36 AM
paint pattern adjustment
Tue, Apr 14, 2009 at 10:55:02 AM
"paint" pattern id?
Thu, Jul 24, 2008 at 1:14:42 PM
Scaling fill pattern
Thu, Nov 17, 2011 at 4:01:24 PM
Solid Drafting fill pattern
Tue, Jun 23, 2015 at 1:35:01 PM
Page generation time: 1.9616
