12 Users Online (10 Members):
Forums >> Revit Building >> Technical Support >> Carrying over line weights in title blocks in RS 2008
32 Posts No Rating |
I've recently started at a new firm where Revit has just been purchased. I am putting title sheets together which are working inteligently, my problem being though is when I load into a project. I have selected medium line thickness for the borders. This remains in the title sheet file itself, but when I load into a project, all lines appear thin. I can't figure out why. Any ideds guys? Many Thanks, Jamie
Jamie Hunter Walsh CE Graphical House, 2 Wharf Street, The Calls, LEEDS. LS2 7EQ U.K. www.walshgroup.eu.com |
the line style (found under settings) has a different line weight in the project than in the title sheet family ie: medium line. when you load it into your project the projects setting is used, i suggest creating a new line style in the title sheet, editing its line weight and loading it into your project.
Delete or Purge out Title Blocks? |
Wed, Nov 26, 2008 at 5:06:00 PM
Line weights reverting to standard |
Thu, Jan 6, 2011 at 7:10:38 AM
Imported AutoCAD 2006 title block line thickness |
Thu, Sep 7, 2006 at 3:27:44 PM
Revit Structure Questions Line Weights |
Wed, Jan 16, 2013 at 3:33:32 PM
Customize new Title Blocks |
Mon, Sep 21, 2009 at 2:55:19 PM
