Forums >> Revit Structure >> Technical Support >> framing elevation tag
Thu, Jul 17, 2008 at 3:28:05 PM | framing elevation tag
nickal220
how would i go about changing a framing elevation tag to look like a section tag (ie. with a tail)
Fri, Jul 18, 2008 at 3:59:53 PM | framing elevation tag
rkitect
rkitect Avatar
4 Stars: 29 Votes
Unfortunately, because of the integral nature of elevation tags, you can not edit the look of the elevation tags that much.  You will need to do the infamous elevation symbol workaround where you create the elevation, hide the elevation (not delete) and then create an elevation symbol in the family editor that looks like the tag you wan tto use.  This tag will not be intelligent at all so you will have to coordinate drawing and sheet number yourself.
Beam Tag with Top of Steel Elevation ?
Fri, Aug 1, 2014 at 8:12:42 AM
Adding length parameter to framing tag
Sun, Jul 18, 2010 at 4:19:26 PM
Wed, Oct 18, 2017 at 11:05:46 AM
Structural framing tag
Mon, Apr 5, 2021 at 1:29:32 PM
Elevation Tag - Leader Problem
Thu, May 17, 2012 at 5:48:20 PM
Page generation time: 1.6842
