Forums >> General Discussion >> Wishlist >> Select only required elements
Thu, Jul 17, 2008 at 12:55:50 PM | Select only required elements
cndcns111
hi everyone,
as am learning revit i came across this doubt (comparing with AutoCAD)
1. is there way to select elements which were selected previously
2. suppose i select a set of elements and want to de-select just one of it, i dont have an option other than coming up again as done before.
is there a way to solve these or does it remail as a wish list item..
 Any suggestions, truely appreciated. Thanks in advance
Thu, Jul 17, 2008 at 1:57:54 PM | Select only required elements
Belinski
4 Stars: 5 Votes
Hey,
 If you select a group of elements and a certain element was accidently selected or is'nt needed, then just hold down shift and select the element that you dont want in the group.  This will de-select the item.
Edited on: Thu, Jul 17, 2008 at 1:59:22 PM
Thu, Jul 17, 2008 at 2:10:18 PM | Select only required elements
If you want to select previously selected elements .... before you do anything else right click and you should have a select previous option.
select elements on current level only - revit 2014
Tue, Jul 23, 2013 at 7:52:33 AM
I can not select some elements in a file
Wed, Apr 10, 2013 at 5:28:15 PM
Given a central model: unable to select some elements
Tue, Apr 16, 2013 at 12:55:06 PM
Can't select elements like in 2011
Wed, Jun 22, 2011 at 8:19:09 AM
work plane
Fri, Jun 28, 2013 at 9:12:11 AM
Page generation time: 0.3117
