Forums >> Revit Building >> Technical Support >> exterior finish error
Thu, Jul 17, 2008 at 11:21:22 AM | exterior finish error
ekhozindar
i looked for this thread to no avail, sorry im sure its somewhere =/
for my exterior finish i need it to go above the core of the wall, however, when i unlock the top of the finish in the wall properties, it gives me an error:
Cannot extend layer(s) of the highlighted vertically compound wall.
however it will allow me to extend the bottom of the exterior. anyone know why?
Thu, Jun 4, 2009 at 1:03:18 PM | exterior finish error
angelosk
i am having the same problem, anyone can help?
www.kaliakatsos.gr
Tue, Jun 16, 2009 at 1:22:12 PM | exterior finish error
Dianthier
Dianthier Avatar
2.5 Stars: 3 Votes
I don't know if this will help, but in my case I had a wall of stucco, CMU and gyp board interior finish. The wall has an opening with a curtain wall in it.
I needed to bring the GB down below the roof level. I unlocked the GB but got that error message when I got past a certain point. Looking at it in section I when stretching the GB above the opening down it was also causing the GB below the opening to move down, I could only go as far as the the height below the opening and got that error.
I found splitting the wall at the top of opening cured this. It doesn't seem to have any detremmental effects. If I move the top piece, the bottom piece moves with it.
It's got to be happy hour somewhere
exterior finsh below zero
Sun, Apr 11, 2010 at 10:13:36 AM
Exterior finish on wall not exterior enough... ?
Fri, Jun 3, 2011 at 8:44:28 PM
exterior wall finish
Fri, Nov 18, 2005 at 9:46:47 AM
Wall Finish
Wed, Aug 9, 2006 at 6:02:51 PM
WALL SHEATHING AND EXTERIOR FINISH
Mon, Jun 19, 2006 at 10:05:55 AM
Page generation time: 0.8042
